My TV randomly turns on during night usually 2 or 3am which is annoying to say the least. I've turned eco to off but still it does it, I have a you view box and a mecool box connected but both are off during night and not on when I check if TV comes on. Any help would be great.
Hi @spotbot1
I would start by physically disconnecting all connected devices to rule out some random HDMI control waking up the TV. Review your Timers to make sure that the On timer has not been set. Disconnect Ethernet or WiFi and ensure Remote start is disabled. It is a case of elimination to rule out everything apart from the TV.
If it is the TV with absolutely nothing connected then it may be best to contact Sony UK Support
