Hi!
I just buy a new sony android tv just for play clash of clans game and its private server is not working when i play game on your TV. Please give me any working tricks that works for me.
Thank you!
Edit - link removed for mod server info
Hello @theclashofmagic,
do you have an Android-smartphone? If so you can get the Microsoft Display Adapter to mirror the phones screen to your TV via MiraCast (which is a feature on Android).
If you now connect a wireless (or wired) mouse via an adapter (called OTG adapter) to your smartphone, you can control the game just like you would using your finger.
I think this would be the best option to play the game if it doesn't work properly on the TV directly.
- Nic
Actually it is a private server like -link removed - and others. All the private servers are mod versions coc game, I do recommend you to play only official Clash of Clan game by Supercell. It will work fine on all sony devices.
Edit - Link to mod server info removed
