Contacted Sony - all their attempts failed.
I tried installing the latest firmware update V2605 online through TV( I have 150Mb cable), also downloaded the firmware and put onto a USB(tried the two file method also).
Every time, via TV setting software update, the download crashes at 64%(states "An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123).
The usb( usb slot 1 and 2 tried) method also crashes out into reboot at about 64% too.
Downloaded the firmware numerous time.
Any ideas ?
I would like to say thank you again for your help!
Hi. I am having the same issue with my KD-49X9305C update. I have tried several times via the LAN connection to the TV and it continually fails around 66%. I have also tried updating with the USB stick but again each attempt seems to restart the TV at around the 66% mark and when I check the version I see it has not been updated.
Can you please PM me the steps to update the software.
Thanks.
Hi tolohan
Sent you that PM with instructions. Let me know how you get on.
That worked for me.
Thanks for the help.
Hello, I'm having the same problem with my 49X8309C, what I should do, it stuck in 92% when trying to update
Hi there
Would help if i click the right button to reply
Ive sent you a PM with some instructions, pleaee let me know how you get on.
Hello, I have the same issue with my 65x9305c, both internet and USB fail... Please help 🙂
Hi, it wasn't easy, but finally it worked! Thank you, Quinnicus.
