Contacted Sony - all their attempts failed.
I tried installing the latest firmware update V2605 online through TV( I have 150Mb cable), also downloaded the firmware and put onto a USB(tried the two file method also).
Every time, via TV setting software update, the download crashes at 64%(states "An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123).
The usb( usb slot 1 and 2 tried) method also crashes out into reboot at about 64% too.
Downloaded the firmware numerous time.
Any ideas ?
Hi all - and especially Quinnicus, who seems to be the man with all the answers
I have the same problems as bowsh123: No internet update available and USB update does not do anything. And my file size didn't fit either.
Could you help me to a solution?
Model: KD-49X8305C
And thank you @Anonymous very much for your support!
Hi @klsoren
Ive sent you a PM with some instructions. Let me know how you get on. Your most welcome.
I am having the same problem with software update with my KD. Not getting solution. Any expert? or i have to start new topic for it?
Can you share the solution with me also, in private message??. I also getting the same issue with my TV.
Thanks.
Hi Quinnicus i have exactly the same problem as Boba77Fet but its a brand new kd65x9305c. it gets to 81% and fails via internet, but via usb crashes 81% and reboots 3 times. Please help
Hi there
Ive responded in your other thread:
https://community.sony.co.uk/t5/televisions/cannot-upgrade-kdx9305c-firmware/m-p/2139923/
I hope you can help me.
I have got the same problem.
Update via Wifi fails every time with error 2123.
Update via USB just restarts the TV.
I have a KD-49X8309C.
I have tried different usb devices tried to restart the tv factory defaults, no luck.
Could you please help me?
Thanks you.
J
Hi jandecoy
Ive sent you a private message, let me know how you get on.
