Contacted Sony - all their attempts failed.
I tried installing the latest firmware update V2605 online through TV( I have 150Mb cable), also downloaded the firmware and put onto a USB(tried the two file method also).
Every time, via TV setting software update, the download crashes at 64%(states "An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123).
The usb( usb slot 1 and 2 tried) method also crashes out into reboot at about 64% too.
Downloaded the firmware numerous time.
Any ideas ?
HI @Sly079 and @Rossdoc81
I have sent you both a PM with some instructions. Let me know how you get on.
Hi Quinnicus,
many thanks for this solution, it works very well !!!
ciao
Roland
Hello, I have the same problem on my KD49x8305. Update via USB stops at 77%. Could you please send me the instructions too. Thanks in advance.
Hi there
Ive sent you a PM with sone instructions.
Thank you very much, it worked very well.
Unfortunately i dont know the answer, just that the US can have different problems to us in the EU. I can only advise for him to post on thier forums. Also, ive not come across that particular problem before either.
A long shot is to pull the power plug for about 1 hour.
Hi @Anonymous same issue here, TV wont update over wifi, tried numerous times to update using the USB method also but it just restarts after about a minute. Is it possible to send me the instructions also? the TV is KD-49X8305C
many thanks @Quinnicus i've followed your instructions and it worked perfectly.
Excellent. Thanks for the feedback.
