I have a KD-55AG9 with which I am very happy ....BUT while I can get subtitles on all channels and Apps I simply cannot get them on ITV Hub even though the programme guide states that they are there. Am I alone with this problem or can anyonme help
Glad I could help and thanks for marking your post with the solution ^^
Now others can find the solution easily thanks to you!
- JD
