Hi
I’m looking for help regards to the power cable on my new tv KD-43XH9196 I’m looking to have this wall mounted and the cable comes with a brick attached !!
is there any other cable that can be fitted or will I have to cut out a hole in the wall and rebate it !
Thank you 🙏
