Why do I have an exclamation mark next to my network settings on my 65X9005C?
My network is fine. Every app that requires Internet is working perfectly.
Hi
Last time i looked into this, this was an Android bug, happens on my Z4 tablet all the time. Just ignore it.
Update your TV to the latest firmware, it should be resolved now
I also have this problem, and then it will completely lose the connection requiring a scan to refind the router. After about 2 - 3 days a scan will no longer find the router and only a factory reset will recover the situation. I have raised the matter with Sony's technical support but they have seemed fit not to respond.
Over the years I have probably bought about 8 Sony televisions and this is undoubtedly the worst model. The support is non-existent!!!
