why are there so many running apps on my Tv (65X9005C). There must be 150 odd sounding apps. Surely if they are required just to run the Tv I shouldn't need to know about them? It makes searching for a real app (Netflix for example) a real chore if I have to scroll and scroll through a list of irrelevant apps.
They are not apps not apps I've downloaded.
Hi there
This is normal operation - even on Android phones and tablets. Many running services are effectively an application - similar to windows.
However, in the apps part of settings, it is separated into 3 sections - Downloaded apps, System apps and Running apps. You dont have to scroll down for the other two sections if you only want to look at your downloaded apps
