I have experienced an annoying issue when casting football to the built in cast. The picture judders due to here in europe most things are broadcast in 50hz rather than the fixed 60hz the cast is setup for. My gripe is that with the built in cast there is no setting to force it into 50hz unlike the standalone cast whereby you can do this on the app settings. I rang Sony and they hadnt a clue and were blaming the source, my phone (iPhone 6) a
and said a Sony Xperia wouldnt do this which is aloada codswallop. Sony should address this issue!
Hi there
Unfortunately this is purely a Google issue. A search (using google), gives me the following:
http://www.trustedreviews.com/news/google-won-t-fix-uk-based-chromecast-judder
https://productforums.google.com/forum/m/#!topic/chromecast/a6zvXuEGxdQ
https://code.google.com/p/google-cast-sdk/issues/detail?id=374#c6
Im not sure where things stand between Google and the Sony TV, as things are integrated into the OS.
