when turn on my Sony Bravia KDL50w755c the beep sound is blemished skewed crackling. Only beep sound. the sound of any channel are ok. I restart my tv and it is all ok
Hi there
Glad all is ok now. If the beep does annoy you, you can turn it off in the settings > sound > system sounds
