I am trying to connect my MacBook and iPhone11 to my Sony Bravia TV to stream videos and Sky Sports etc, but the airplay function on both the phone and MacBook isn't picking up the TV.
I have the latest versions running on both devices but still no luck.
The Chromecast for the BT Sport App works fine however.
Any advice would be great.
Thanks
Martin
Hi Martin,
Have you tried a factory reset?
Best wishes,
M
@MLittlewood ha scritto:
Thanks
Martin
On which Bravia TV? Is it airplay enabled?
No, worth exploring?
Yes, it is enabled. 65XG87
Worth exploring what? If you don't know it should suffice you write the model...
You should see airplay in the settings like in this introduction...
https://www.sony.co.uk/electronics/support/articles/00231372
Thanks, I'm not sure if the TV has the latest Pie firmware?
How would I check this and if its required how do I download it to my TV?
Thanks for you help.
In the link I put in the post there are detailed instruction on how to check it and how to install it from the web if the TV does not recognize that a new version is available
