Hello all, I'm having an issue that started very abruptly and that's making me a little bit crazy. The rear wheel on my a7IV is behaving like it's stuck and keeps scrolling continuously.
Here is what I tried so far:
- Remove battery and turn off/on again.
- Reset settings
- Reset to factory settings
As far as I've observed, the issue doesn't seem to be software related but I figured I'd ask around before contacting Sony and looking into activating the warranty.
Has anything similar happened to someone here?
Thank you very much
