Does Xperia 5 support raw files?
Not with the standard camera app, no.
But you can use other camera apps that support it. It's not a hardware limitation, only software
Use Adobe Lightroom, you can take .DNG raw files
Thanks! I've already check out and it's working. Nice! 🙂
