Does front camera support Autofocus(AF)?
SOLVED
ds2mph
Visitor
It is not written on the specifications, so I'm curious if front camera supports AF.Screenshot_20190313-014355.png
1 ACCEPTED SOLUTION
Accepted Solutions
Jonas
Master
Hi @ds2mph, thank you for your question! Slightly_smiling_Face
The front camera does not support Auto focus.
I hope that answers your question!
2 REPLIES 2
profile.country.LT.title
EUPHORIC2017
New
About Xperia 1 you can find in link which i posted. It's offcial Xperia 1 web site, so you can trust it 100%. But you are right in wbe site is not mentioned about front camera, but i found article from GSM Arena about this model, check it i hope will helps you (i did not read it, but GSM Arena is one of trust reviewer, also XperiaBlog (Unoffcial). By the way there is PhotographyBlog in which maybe you will find information which you wnat to get Slightly_smiling_Face
Jonas
Master
