By mistake I transfered all my pictures from the memory card to mobile phone memory.
The phone does not start (reaches the Sony logo black screen).
I did all the resets / restarts but is not starting.
Any ideas?
If your mobile is totally unoperational then you have no choice but perforing a software repair via PC Companion, this will do a clean installation of the latest firmware and will also wipe your internal memory.
Turn off your phone and leave it on charger for a couple of hours and leave it off -> Open PC companion -> Support zone -> Phone/tablet software update -> Repair my phone/tablet (blue link style). Follow the steps given, do not connect your phone until prompted to press volume down while plugging USB cable.
