See if this helps:
My phone has been trying to updating it's self since yesterday. It says installing nothing else. Does anyone know how to stop the update.
The update can't be installed by itself you have to approve it, are you trying to install it or just avoid getting the notification?
Hi @Fikret77
Please, tell us to which version of Android are you trying to update your device and if you are running this update via PC Companion (your device is connected to a computer) or OTA (you have been notified of the availability of an update on your device).
I have approved it on my phone. It has started to install since yesterday. it said it will take around 20 minutes and won't be able use the phone. I am connecting via WiFi for the download.
Perhaps you don't have enough free internal storage or your connection gets disconneted or too slow
you could use PCC instead
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Keep us updated
