I recently updated my phone with the latest update, it was working fine. Their was a marginal improvement in the battery backup etc. but after charging it today, i noticed the standby time being shown as only 10 hours in Stamina mode. I chose to reboot, and since then my phone is stuck at a repair kind of icon with z moving status bar. I can't find any reference to such incident online. please help how to fix.
http://talk.sonymobile.com/thread/129071?tstart=0
guys just follow the instructions once you have downloaded sus
try and do a backup first
power button volume down to start
im also having the same problem dude..
still waiting if some one replies
i found dat u can recover using SUS or PCC ...
but anyone can tell how to do that?
I am on Mac so I tried restoring using bridge, but it fails and says no update found after i plug in the cable...
yes i have seen that post..
but i dont know how to use SUS (sony update service)
can u explain please
run sus - and you will see an option "repair my phone" select it and follow instructions - it will reload the FW
you may get started in safe mode - volume down power button hold
GeoffH is right. SUS should work.
Just try SUS last night it work ! Thanks !
How is work ?
1. Download and install SUS.
2. Turn off your phone.
( If your phone dead and keep showing repair icon and can't switch off please hold the power and volume up button until the
FIRST VIBRATE 1 time than SECOND VIBRATE 3 times after it will off. )
3. Open SUS and hold the phone volume down and connect the usb to computer.
4. After restore the factory setting online around 30min complete.
Good Luck !
The solution on Mac didn't work.
I had to reset and update my phone using a windows desktop using SUS.
Thanks GeoffH.
