Hi. I can't use sociallife for facebook. can't post or comment but I am able to use it on twitter.
it gives an error message when commenting. tried disable the stamina mood, uninstalling and reinstall again but nothing changes.. Please, kindly advise.
I had issue somewhat similar to yours, but my xperia did not want to upload photos through facebook for xperia app.
It turned out to be facebook issue, not xperia. I fixed it by going onto facebook on my PC and checked apps settings in facebook. Facebook has been updated, and new update recognized xperia app as an third party software and blocked it by default, check your settings in facebook, it might be just that as we did receive facebook update few days ago
Does it show you posts from facebook or isn't your facebook account working at all?
I had this problem with my first XZ but with a replacement facebook is working. I didn't change settings of my facebook account in the time between. It's a bug.
My account works on the Facebook app just not on socialife. I only manage to get the feeds but can't post a status nor comment on one.It works perfectly on Twitter, though.
Power, Vedster! It's working now. You my ninja! thanks
