Hi!
I have my Xperia Z for year and half now with no problems. I showered with it with no problem, but yesterday, I had some mess on display, so I washed it in water with fingers holding usb slot (rubber isolation fell off). After that, everything went ok, but few minutes later, first, power button was delayed and sometimes it doesn't work at all and second, touchscreen is not responding. Everything else is absolutely ok, notifications and so on, only these two things don't work. There's no crack or water under the display.
Already tried reseting.
Thank you!
Hi @Serpentes
Seems to be a hardware problem, you have to consider visiting a Sony service:
Hi @Serpentes
