hello
i updated my music informations with gracenote via the wallkman application
but some informations were wrong, i was able to correct them, but now i have duplicated albums
for example album A with songs 1, 2, 3, 4
and a second album A with songs 5, 6, 7, 8
how can i merge the 2 albums A in one and unique album A with songs 1 to 8 in it?
i tried to turn my phone down and on after the modifications on the songs property to see if it changes anything, but it doesn't
i tried to do it with media go application on my laptop but i have the same issue
has anyone encoutered the same issue? and/or knows how to fix it?
your mp3 tags are messed up - common problem
may I suggest you get the Android application MP3 edit - single best bit of software I have on my phone, you can select both the album entries and make sure they have exactly the same info - you will find right now they don't
great application indeed
thanks a lot
