x
Xperia Z camera in Low light
SOLVED
shreekanth_rs
Visitor
Is the xperia z camera in LOW light is better then Xperia p (low light ) ..? heard many poor reviews about xperia Z camera in LOW light ..! Was using xperia p ,have decided to go for xperia Z . Help me out guyz.
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.GB.title
Uliwooly
Expert
do you have an issue? low light its great, it's better if you have HDR on, also if you have normal settings and play with metering, ISO, etc for best results or superior auto will be ok too.
4 REPLIES 4
Uliwooly
Expert
jluisfa
Visitor
shreekanth_rs
Visitor
Thanks guyz..
Uliwooly
Expert
anytime
