Hi, for the last couple of days I have seen that the Walkman widget that is present in the lock screen when I am listening to music is absent.
As you can see in the pic, the Walkman is running but the widget is absent.
Any suggestions will be appreciated.
Hi Senhoy, thanks for your response, I already had widgets enabled.
However since you guys mentioned removing Smart Key, I went into the Smart Key app and turned OFF the Music (default) and now the walkman widget and my calendar widget is now accessible on my lock screen!!! Thanks Guys.
Isn't there anyway to get this to work without removing smart key ?
Disable music like the user above suggested.
I was hoping I wouldn't need to do that.
Other option would be removing smart key app.
Good day, I have a similar problem I can't add any widgets on my lock screen and "settings> security" is not present as an option. How do i fix this? I just upgraded to Android Version 5.0.2, Build number 14.5.A.0.242
