Hi, for the last couple of days I have seen that the Walkman widget that is present in the lock screen when I am listening to music is absent.
As you can see in the pic, the Walkman is running but the widget is absent.
Any suggestions will be appreciated.
I can't see the picture until its approved by a moderator.
do you have a pin lock, password lock or pattern lock?
As uliwooly guessed,are you using smart key?
Hi Admin, I also noticed this too since upgrading to latest Android software.
I always had used patern lock screen and the Walkman widget to stop/play/skip tracks was always accessible until after the upgrade.
Also I was able to access my calendar widget by swiping to the right, but now that is also not there.
Can you see the picture now?
No, I don't use any of those
I just use the swipe Method
@alexdon yes, I use smart key
Should I uninstall it?
No other option 😕
You are welcome.
Answer for Kerioke:
Go to settings> security and check enable widgets if unchecked
