Greetings!
This message started occuring today after booting and whenever I open google hangouts (all the time)
I am using Google play services v3.1.36 and I am on 10.3.A.0.423 (C6603).
Please no recommendations like "clear cache / data, uninstall updates, hard reset etc". Assume that I have tried them and nothing worked. Just reply if you are sure about your answer, it will save us all time. Thank you in advance.
fortunately, today it doesn't happen at all. I guess it was temporary.
that seems to be either a google server issue or a network connectivity issue, hardly doubt it but it could be another app acting up
