Do you guys know if Sony Xperia Z5 supports USB Battery Charging 1.2 (BC 1.2) Specification.
@skylinedreamer
I have received information that it does support Battery Charging 1.2.
However, regarding what you are trying to do I am unfortunately unable to assist you.
Hi @skylinedreamer,
I'm afraid I can't find any specifications for this. I will see if I can find more information.
Hi Christofer,
I am trying to develop AOA protocol with a USB host driver capable of BC1.2 Spec.
Seems like Z5 is not able to support BC1.2 under CDP mode. It works fine in SDP.
It would be great, if it's able to do so in the future firmware releases.
Regards,
skylinedreamer
@skylinedreamer
Thank you for the information Christofer
