@ElTano Can you first check if stamina is set to always? Also, can you try to reset it like this: first disable it, then go to settings-apps-all,scroll down to stamina app. Tap on it, force stop and clear data. Restart the device.
you could repair the phone with PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
@alexdon could you test this out?
