Hello,
Since a previous update (not the last one), I can't stop auto rotation on my Z1. It's a real problem and rebooting the phone doesn't change anything ! I feel like I'm the only one on earth to have this problem, others have the opposite issue
What could I do ?
Thanks in advance
No, it works in safe mode. But how can I find which application causes this problem ?
Trial an error, open the app drawer > swipe left to right > installed > uninstall one by one.
@Don_Quixote wrote:
Or are you using an magnetic charger?
....yes I do... (I broke the "door" of the usb port of my 1st phone, because I was opening it too often, so...). But I have the problem all the time, do you think it's related ?
