Thanks for the answer.
Already tried a few times, still the same.
Safe mode, same problem.
I've delete all the applications I could, nothing change.
I can use the phone in glove mode but it's still very difficult to touch the navigation bar, and notification menu impossible to slide down.
Yes, repaired and factory setting reset.
I'm having the same problem.... my drop down menu works but the 3 bottom buttons don't work... seem like thay are depressed permanently....
the advice seems to be fix it with PCC, but given that I haven't seen anybody in the forum say that it worked for them, is there really any point in us doing it?
So I'm still a bit confused... is it a hardware or software problem???
That's how you narrow down if its a hardware or software issue, just repair it with PCC and report back.
based on all your replies, your problem might be hardware related, contact your Local support to get your device inspected, keep in mind that this is a user based forum
