Wow!!! what a solution.. I have got the update message from Sony then updat to lolliopo and now pay 300 SGD....
Okay, this is the last phone I have purchased from sony. Very bad experience. Never hope this type of performance from a high end phone. I have paid 500 USD for purchase this phone...........
hey! i have the same problem..were u able to fix it?
Got the same issue, but I couldn't try yet the restore procedure.
I found some kind of a "workaround", if you have the Orientation lock disabled, just turn your phone to the right until the screen its upside down. If the issue is with the screen, then once is the other way around you will manage to use the non working keys/shorcuts.
this should work until Sony releases something as a patch to get things back to what they were.
G
Hello every one... I am suffering this problem from last 3 months... I do not get any solution from any blog..
At list I got an apps which help me to solve this problem temporary... I am giving the apps download link you can try to use this......(Still now looking for permanent solution.)
Apps Download link: https://play.google.com/store/apps/details?id=wq.myhomebutton
Thank you every one.....
