i got my u.s warranty xperia z purple yesturday and i would like to know why i'm still stuck with firmware 434 and why i can't get the latest 253.
i try on the phone and no update, i try on the computer with pc companion and nothin, i try to repair the phone and it still says i have the latest firmware. what do i need to do to get the latest firmware 253 ?
it doesn't seem to be available, but you can manually update your phone
How to manually update, downgrade, root 2013 Xperias
there are other threads on the same topic, since you are new user I'll explain briefly how the forum works
use the search bar on the top right before creating a new thread, chances are that there is a thread on the same topic.
now back to the topic, each update has to be approved and then released in each country/region, if your phone is or was locked to a carrier/network branded, you have to wait for them, carrier/network, to approve and release the update.
in other words you have 2 options
1) wait
or
2) manually update your phone
i got mine unlock and thank you for taking the time to explain how things work here
do you happen to know if the firmware 253 still not in the u.s - new york ?
thank you sir for the replies
anytime
this might be handy
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
I'm using the C6602 as well and never got the .253 update (California, USA here) but the other day I did get the .307 update. Received it when I connected to the PC Companion.
indeed, there seems to be some issues with OTA notifications, its wise to check with either PC Companion or Sony Update Service
