Hello,
I am successfully able to connect my Sony SBH50 with my Xperia Z via NFC and it shows all the app extensions. But I am not able to play my music from Xperia Z in the headset.
Instead when i am connecting by bluetooth only, i am able to play my music on the phone in SBH50. My question is:
1. Does not SBH50 support Music play via NFC?
An early reply/solution is highly solicited
NFC can't stream music. In this case NFC just initiates the Bluetooth pairing and connection process.
Go to the Bluetooth settings in the phone and check the pairing for your SBH50 and that you have both phone and music enabled.
It is called NFC enabled Bluetooth device...
It works with Bluetooth, it automatically power on BT...
Yes I can stream music over Bluetooth. I was thinking if NFC also could stream music.
Anyways thanks for the answer..
