Just make sure you are on manual mode.
Thanks YoGem, but I forgot to mention I did turn off this effect manualy and it still remains. Hey Sony, please help meeee:smileycry
Hi Alexdon
Even turning off the effect it persists.
same situation
adding my old post, this effect came back again and can't be fixed !@#$
So are there any Updates on this Bug?
I have this on my Z3 and its a bit "annoying" 😕
Did we get a Software Update soon?
No this does not work.
Did you also used the Front-Face Camera ?
I wonder if I can get my money back using the warranty because of annoying soft skin bug. I know that Sony denies it and makes all the excuses possible but come on. If you simply google: "sony z3 turn off soft skin effect", there will be 100s of people talking about this problem. How can all of them make it up? As for me, I have posted a message about that with pictures, explaining everything, then I emailed the support team but nothing has changed. So I am fed up. How can I keep this phone if Sony can't fix one simple mistake?
And here is my last post: http://talk.sonymobile.com/t5/Xperia-Z3-Compact/Soft-Skin-effect/m-p/922975#M5935
