I dont think so. Are you trying to take photos in low light?
In proper daylight or well light room front cam gives good results. At least what i m getting.
I just take photos on snapchat and screenshot them, only way I can get the Blur off, still a shocking front camera
Sony has obviously screwed up but they won't admit it:
link: /t5/Xperia-Z3-Compact/Soft-Skin-effect/td-p/838361
I'm unlike the others providing you with screenshots:
Is there anyone who emailed them about that as well? If not, I will be next I guess.
This, is the exact problem.
I can confirm that, smooth effect appears to be on no matter what settings you change. Fix this, PLEASE.
Proof by me. look at the difference between screenshot and postprocessed photos.
That has worked for me, thank you!
For reference for other people I'm using a Z3 Compact
I'm having the same problem. Why doesn't Sony fix this. I mean what's the point in biting a high end phone and have bad camera!
