In Lollipop, this has been changed. When you receive a text message and you are using the preinstalled messaging application, only the messaging icon will appear in your notification field and no floating/scrolling text like in previous software. Unfortunately, I'm not aware of any third party apps that have this kind of feature but there might be some app via Google Play that has it.
could you post screenshots? (make sure to black out any sensitive information/private info)
