Hi everybody!
Its time to start sharing you home screen layout!
This is a fun way to get inspiration on how to configure your home screen layout.
I personally like a standard layout. :smileysmileythumbsup:
You can use the Screen Mirroring feature to share the screen of another Xperia™ device on the screen of your device without using a cable connection. You can also view content on your device on a display or TV that supports Wi-Fi CERTIFIED Miracast Plex Lucky Patcher Kodi
It's looking good
Después de probar muchas roms, vuelta a stock con root, cero fallos
After trying many roms, return to stock with root, zero failures
You can always use the Screen Mirroring feature to share the screen of another Xperia device on the screen of your device without using a cable connection.
Regards,
用了多年,都是一樣咁好。
After years of use, it's all the same.
gt
