Tried even SUS & PCC as suggested but nothing works! My beautiful phone is just lying there....
take your phone to a Sony repair center
I tried your way again and charged it for an hour and tried to turn it on... The LED blinked and then went off.. the phone didnt turn on..:smileyplain:
take your phone to a sony repair center.
I will but just wanted to know if theres any other trick / tweak up your sleeve which i should try
there aren't any other suggestions I can think, sorry.
Hey uliwooly, thanks for the advice, went to the Sony Centre yesterday and they declared the battery as dead and confirmed that they would need to replace the phone.
A l'il dissapointed the way it turned out but hey i'll get my new ZL soon (expected in the next 7 days)
Till then i'll use my Xperia Arc and manage... I'm an Xperian for life!
Uliwooly hellllppppppppppppp! My NEW, REPLACEMENT phones not turning on I left it on charge for a couple of hours in the morning with a little over 20 % battery & it was fine but now its completely DEAD! No LED light, not turning on, NOTHING!!
PLS PLS PLS HELP!!!!
Yes Mr. Super User... i'm trying that now... Shall update after an hour
DIDNT WORK!!! :smileysad::smileysad::smileysad: HELPPPPPP
