- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi everyone,
The drag down quick settings menu has disappeared from my Z3. Dragging down from the top with 2 fingers does not bring the menu down. Neither can I use the notifications at the top right to access the menu. However, I get to the sounds setting panel by using the volume button.
Tried this:
Settings > personalization > Quick settings
but I do not see Quick Settings option.
any suggestions pls? thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My droppped my phone and the screen was broken so I had it fixed.
I found that the Dragdown menu disappeared so I tried Factory reset, yet it's not back.
Please tell me what to do.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey! Just wanted to add my solution in case someone else has this problem:
Pull down from the top and tap on the pencil icon which opens the Edit menu for the quick settings. Tap the upper right icon (the 3 dots) and tap 'Reset'. All the icons you had in quick settings should be back.
Not sure how they got cleared but this fix worked for me!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you! Had this problem for a while but this fixed it ππΌππΌ
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Liachia wrote:Hey! Just wanted to add my solution in case someone else has this problem:
This worked for me on Huawei android, year 2019, Android 7.0 ,
but firstly I had to drag at least one icon to the top as if I wanted to remove it from the quick menu, only then I was able to "reset" the icons, which ultimately fixed the problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
There is a tab offering combined or separate, make sure it on combined otherwise your quick settings will dissapear.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Repair shop! Warranty I hope, if not its cheaper to get another phone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you, thank you, thank you - this worked for me!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@spacekadet wrote:@Nailz
I cldnt work it so I took it to the service center yesterday. the staff ran the diagnostic test and said the phone needed a LCD replacement.
Try this, Settings >> About Phone >> Diagnostics
Good luck
Had this problem on a Huawei, solved it by resetting the quick menu via the edit quick menu button
- Β« Previous
- 1
- 2
- Next Β»
NaznaΔite sviΔanje na Facebooku
