Why does the camera in Xperia Z3 open directly in landscape mode? How can I prevent that and keep it in portrait mode?
Not sure I understand your question - Are you saying that turning the phone to portrait doesn't work or do you mean something else?
Not sure but I think it is related to the resolution and ratio. Try to set it on 4:3.
Strange,I have read here on the forum that the settings you apply to manual mode are reset when you exit the camera. Maybe @uliwooly has an idea about this.
Great,I was about to ask you that. Marked your answer as correct.
my camera button was loose..i can't pick a picture in water..
