Hi there, I have Z5 compact for 2 months and generally I am very satisfied. However I have a small problem with messenger.
I can't read some stickers that I send or I receive from a friend. I make many refreshes or even restart but i cannot read them. (In my desktop I can see them normally). The situation is like that:
Any Ideas?????
Thanks in advance.
Ok so its the Facebook messenger, there's not much to suggest here, you can try this
settings > apps > all > messenger > clear data > restart the phone > check again
but you might have to contact the app developers (facebook regarding this)
Email [email protected]
which app are you using? could you upload the pictures to box or dropbox or drive and post the link here as I can't see them until they are approved by a moderator.
Of course Uliwooly. And thanks for your answer. I always use the official messenger application.
The images:
http://postimg.org/image/svj2efxc7/
http://postimg.org/image/s4qc8nuyv/
From a cross check that I did now from my desktop, I realized that I cannot read moving stickers (eg. moving Minions or moving Biscuit) but not all of moving stickers. Some moving stickers I can see them normally....
Oh yes Uliwooly!! It worked!! I can't understand why, but it worked!
Thanks again for your time man
Best Greetings
Thanks uliwooly I was searching for an answer to the same problem with stickers not showing. I did as you suggested , thanks a bunches for your knowledge ...it worked
Thank youuu, this just helped me too!
