my mobile was aking for a update,
i did what my mobile ask, by the last step the computer says a error try again,
on this moment my mobile is not starting up i see only sony and then off.
what is the problem? en how can i fix this?
try SUS instead
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Have you tried to do a repair of the phone software?
Click on this link to get Sony PC companion:
http://www.sonymobile.com/gb/tools/pc-companion/
Start PC companion, start "Support Zone", start "Update phone software" and click on "Repair".
Follow the on-screen instructions.
that was what i try but there is the problem...
i must restart my phone.... only the phone shows sony, and than my mobile gets off.
try SUS instead
