hello I live in Argentina and I have a xperia Z
still not getting update 253
may take both?
you have to wait for the update to be approved and released in your country
but try with PCC or SUS or Bridge
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Try to use pc companion
Bridge (for Mac)
or
How to manually update, downgrade, root 2013 Xperias
http://talk.sonymobile.com/thread/124152
@corsiland there is no need to create new threads on the same topic
funny same care how many open issues, the same issues would open less if they gave real concrete answers.
no You have to wait for the update to be approved and released in your country
global updates should be normal
no upgrade, downgrade .....
connect usb and ready updated
so is sony
if they paid attention that all users will see the same claim
contact Sony and let them know how you feel, this forum is for users to help each other
http://www.sonymobile.com/global-en/support/contact-us/
btw there aren't global updates, it has to be approved in each region/country
you can read about the process here
from source code release to software upgrade
