Hi.
I have a Z3 dual.
Is It normal the internet connection for the chip#2 are blocked during a call by chip#1?
tks.
Yes,the device is dual SIM dual standby,while first SIM is in use,the second becomes inactive. I think that means mobile data too.
The device Sony xperia Z3 is dual SIM dual standby,while first SIM is in use,the second becomes inactive, that means mobile data too.
Sony xperia Z3+ Dual SIM (Nano-SIM, dual stand-by), which means it will not work the internet when you are on the phone. Thats sad, i know, but it is a very small inconvenient.
