Is your display only showing black and white or something?
May want to check the following settings:
Settings > Accessibility (Under System) > Color inversion and Color correction (Both under Display)
@rice_eater
Nice work
@AdrastosDK Check this out
http://talk.sonymobile.com/t5/Software-Updates/Lollipop-New-Features/m-p/955490#U955490
