media server is consuming 40 % of my battery...
actually what is mediaserver ?
how to solve the issue ?
media server is the second user after display - from what I understand it handles syncs with stuff like FB - walkman - google+ etc, so if you are setup to sync a lot of stuff it will be active, although consider that 40% of battery usage is a relative term and is simply compared to other processes on the OS so it may not be using that much battery - my battery duration has increased considerably since I got the phone a week ago - my big user usually 70% plus is the display but that's because I had it full bright and was constantly playing with my new device
may i knw hw much ur battery lasts ?
i had chargd ma fone fully today and it drained by 2 pm....
very disappointed wid battery.....
som r sayin dat d capacity will increase aftr 10 days or somthn !
out of the box mine on a full charge lasted a few hours, now easily a full day
consider this -
Battery will depend on your usage profile, for an average user you will get at least a day
It is reallt depebding on stuff like screen brightness and how long you have the screen illuminated - what apps you are using - constant sync activity - GPS wifi BT, I know for a fact that GPS will drain your battery fast on any phone, couple that with the screen on during navigation sessions and it is a charger only situation
Don't forget you have a device with quadcore cpu and high end graphics some things are just not meant to run on battery - I have a game that I installed it is very graphic and cpu orientated - I'd say it pushes this system to the limit - I know the system is working hard because it gets hot and even with the charger plugged in it is still discharging the battery - yes this game would eventually cause a shutdown even when plugged into the mains lol
so you need to consider what you are doing and where - if you are using GPS etc then have it on a charger
I view these phones like my laptop as opposed to a phone - it has a battery but will be limited if you start pushing things
I had the same problem with media server draining my battery like crazy. Something like 37%. I went from 100% to 18% over 10 hours with only using the phone 3 times for a total of 40 minutes doing simple web surfing and calling.
But I think I found a solution, I just turned off 'media' in running apps and it seems to work to the trick.
Now I don't get media chewing up battery life and since last night I went from 95% to 85% in 9 hours with only making a phone call during that time. I also had stamina mode turned on during that 9 hours overnight.
you may also have a corrupt file somewhere like an MP3 or similar
