Has anyone enabled Talkback feature? It freezes the phone and slows down like anything that I couldn't even scroll down.. What the heck is this???
anytime
I have the same problem. I just updated my Xperia Z to the latest update (4.2.2 Jellybean, firmware 10.3.A.0.423), and decided to try talkback. The phone immediately became sluggish and unresponsive, and I am now unable to scroll. This means I can't disable the feature from the settings menu. Every menu item is highlighted with a box, and accompanied by a vibration. I have tried restarting the phone with no success, so I'm now in the process of repairing the phone using PC companion.
No need to repair using PCC.. U can change the settings again.. I know its quite heavy and difficult do but try it.. just disable talkback..
