Hello guys I need help. My phone fell off my pocket and the screen got broken and the display is still working but the touch response not. So I need to turn the usb debugging on somehow without using the screen so I can get to the phone. Any tips ?
Hi @Hajmy, welcome to our forum and I'm sorry to hear about your device.
There is a guide here at our forum that I wrote a while back on how to enable USB debugging and force the phone to use MTP mode so you can connect it to a computer and transfer your pictures / create a backup. You can find it at the link below!
/t5/FAQ/How-to-perform-a-backup-transfer-data-when-the-touch-screen-isn/m-p/1212631
Let me know if that helps!
Thank you very much man you helped me really good. Its working
Hi again @Hajmy,
You're very welcome and I'm really glad to hear that you were able to get everything working!
Let me know if there is anything else I may assist you with!
w0w great support forum admin
Hi @HerbertJones, thank you for the kind words!
Let me know if there is anything I can assist you with!
For now I don't have problem on my phone but I think I love to buy that latest phone of sony.
Hi there!
I challenge you to go to the next level:
My phone is in same conditions, broken screen, (touch doesn't work) but visible, USB debugging disabled and OTG disabled too (or at least it doesn't work for me, not even after rebooting).
Is there any way to take control of the phone at this point? (the rest of it works perfectly).
I've tried some adb things, but no luck without debugging enabled. Any ideas? As far as I know, there is no recovery interface on my Z5 Compact by default, so chances become less I think.
Thank you in advance!
Hi @agro, sorry to hear about your phone.
Have you tried with a different OTG cable/adapter, or a different mouse? Just to make sure that either of them is not the cause of the phone not detecting the mouse so you can operate the screen with the mouse.
You are correct that there is no recovery menu / interface in our Xperia devices and without having USB debugging enabled and forcing the device to MTP mode, you will not be able to access the internal storage using a computer.
Let me know how it works with another mouse / cable/adapter!
what do i do if my screen is fully broken and i cant see
