Any idea how to rearange or delete them? I do not know am I missing something, but long press on the widget gives me nothing and now I am stuck with bunch of lock screen widgets Everything works fine so I do not want to do hard reset to see if it fixes lock screen widgets. Any step by step on what I am missing at managing lock screen widgets? :smileyblush:
how did you add this widgets? which widgets? can you post a screenshot?
interesting, I have the Xperia Z and still no 4.2.2 but what if you go to settings > security > lockscreen
what happen when you long press a widget? do you get an option do remove it?
did u solve it?
I've the exact problem on xperia z.
please let me know how to fix it if u know, deeply thx.
Something was stuck at first. Now it works just fine.
thx.
I've just restart the phone and then all the things ok.
