THANK YOU THANK YOU!!!!!
Thank you!!! i had problem my earphone stopped working i clean it.... and both of them stoped working.... i was desperate... and then you came sir! thank you
Thank you so much dude. Its working fine for me.
You're right! I was using SoundAbout for almost 4 months since I was not able to find time to go to the Service Center; Finally, frustrated, I decided to have a look again at the forums, and your solution was the simplest one yet the only one I hadn't tried yet. It worked!! Can't tell you how happy I am! Thanks a lot!
this didnt work for me 😞
i uninstalled everything that i downloaded. basically did a factory reset and it picked up my headset but only for a few SECONDS
