I tried many things...including cleaning the jack,clearing the data of SMART CONNECT but the problem resists..
the keeps disconnecting the headsets....
is it a software issue or what......in my country,theres no as such authorized sony customer care for XPERIA.
what shuold i do to solve the problem.
plzzz help
Hi, the day or previous day that this happened with your headphones...had you downloaded/installed any new apps or had you just downloaded any software updates :smileysmileywink:
YES i had installed POWERAMP music player.....
i yeterday uninstalled it nd even deleted its data from the phone.
the phone now recognizes headphones but keeps disconnecting
Consider performing a system repair using Pc Companion as this will often fix issues - This will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
I face it many times when I remove headphones while the music is being played and try to plug it in again. Just reboot your device when this happens. Haven't found anything new.
